585,722 active members*
4,396 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Setup and wiring of Mach3 USB 4 axis Motion Controller AKZ250 from Leafboy77
Results 1 to 12 of 12
    Dec 2014
    10
    AKZ250 Setup wiring - YouTube
    I have spend some time setting up and wiring this card so I thought it would be worth sharing.
    In the PDF attached made a wring diagram for motor drivers, E-stop, Relay, Probe and limit switch (I used a proximity type).
    In the video (17min) I go through the steps in Mch3 and show the actual wiring.
    Mar 2014
    1131
    Re: Setup and wiring of Mach3 USB 4 axis Motion Controller AKZ250 from Leafboy77
    I have the AKZ250 with 4 cheap BL-TB6600-V1.2 drivers. There are only 4 input on the drivers which are:
    +5v, CW, CLK and -EN
    I connected:
    XD to the CW
    XS to the CLK
    +5v to +5v
    But I don't know which output to connect to the "EN" on the driver. I think this is important to enable/disable the steppers on clicking the Reset button. With this setup the motors works but when I click to "Reset" button to disable the motors there are still power on them. Can you please help me on this?
    Many thanks in advance.
    Best,
    Suat
    Dec 2014
    10
    hi Suat, I do not have experience with the driver you are using but from what I can see in the documentation for it the 4 inputs are the same as for most other controllers. Hence, my expectation is that you do not need to connect the ENable at all.Click image for larger version.
    Mar 2014
    1131
    But this way the steppers are always active even when I press the Reset button.
    Sent from my GT-I9300 using Tapatalk
    Mar 2008
    45
    I wonder if you have tried wiring up an MPG encoder to Inputs 0/1? I have been unable too get MACH to repond too my MPG which is tested good and shows input on board LED's. I think I have everything configured correct but still not working.If I use the inputs as general purpose switch inputs they work fine.
    Gerald
    Apr 2013
    1899
    Quote Originally Posted by MartinBarfoed View Post
    I don't understand... you put a resistor in series with the limit switches? Why? That is very unusual...
    Apr 2013
    1899
    In this case the steppers are always energized and that is not a good idea. Better to use EN as it supposed to, to enable/disable the driver and energize the motors when needed.
    Apr 2013
    1899
    Quote Originally Posted by Azalin View Post
    I connected:
    XD to the CW
    XS to the CLK
    +5v to +5v
    Best,
    Suat
    I don't know that AKZ250, but isn't there a free output you could define as EN and use the signal? You don't need one for each stepper driver, just one which you could use for all drivers.
    Mar 2014
    1131
    Quote Originally Posted by A_Camera View Post
    Yes, I did it the way you as you say. I've used a free output port to enable/disable steppers.
    Jun 2016
    18
    You means it can't stop runing when you click the "reset"button? I met the same situation,
    Apr 2013
    1899
    Quote Originally Posted by DanTeng View Post
    I don't know who this question is addressed to...
    The running/stopping is not a problem, it is controlled by step signals, so if no step pulses are sent then the motor stops. The problem of not having EN is that the motors are always getting power and are using full holding torque even when it is not needed or directly undesirable. If you for one reason or other want to disable the motors or release the torque you can't do that unless you switch the power off. Limit switches are not working as they supposed to because if you hit the limit switch the motor is still energized and you can't do anything unless you jog off with the electronics, no manual twisting if the lead screw is possible. If you happen to hit the table due to wrong Z height you hit the Reset or Estop button but while the machine gets stopped, the pressure on the tool and the work piece as well as the ball nut/screw is maintained until you jog off, which is not good at all.
    I know not everyone is using EN and they are happy anyway, but in my opinion that's not a good engineering work. But that's just my opinion.
    hi could you solve the problem?
  1. Z Axis auto zero plate wiring on usb motion controller
    By phongshader in forum Chinese Machines
    Last Post: 11-10-2017, 02:01 AM
  2. AKZ250 USB controller - no output
    By MartinBarfoed in forum Stepper Motors / Drives
    Last Post: 12-12-2014, 07:10 PM
  3. Spindle PWM not working with AKZ250 motion control card
    By curator_ami in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2014, 11:35 AM
  4. Four axis Controller Mach3 Configure+Wiring
    By winattitude in forum Controller & Computer Solutions
    Last Post: 08-27-2009, 08:12 AM
