585,754 active members*
4,168 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Partner 1F Runtime Error 216
    Feb 2009
    5
    I have a P1 serial number 2207, 1069-B, date code 351. I get the runtime error 216 at 00EF:2881 every time I use the machine, usually a hour after start up. It doesn't matter if I cutting chip or idling with the servos off. I also had at times a "unhandled exception 000E at 020730F4 Errorcode 0004", "unhandled exception 000E at 03270ED5 Errorcode 0004", or "unhandled exception 000E at 04372677 Errorcode 0004". But the runtime error 216 seems to be the most frequent one. I replaced the power supply and reloaded the parameters with no change. I called Milltronics and they said it was a memory problem and that I could try to replace the 32MB CF card on the mother board. When I was on the phone with them I asked if I had to have the CF card "programmed" before installing it and they said "no". I ordered a new 32MB CF card from ebay and when I put it in the control it wouldn't load anything, was stuck at "non-system disk or disk error replace and press any key when done", I am guessing we weren't on the same page or the card is bad. So if someone could please help me figure out how to install the new memory card or give me any other insight it would be much appreciated.
    Dave
    Feb 2009
    5
    Re: Partner 1F Runtime Error 216
    I called Milltronics back to get there opinion. According to there records my control was in its original state. After i explained it had a CF card ( and no simcard ) they said someone other then Milltronics has updated the control. They also told me that I cannot program the CF card (which i kind of thought). I would like to ask if anyone out there has advise for me before I send in the control? Thanks in advance!
    Jul 2010
    548
    Hi BlueKat. PM ME.
    Sportybob
    Sep 2010
    529
    I modified my machine to have all the software on a CF card rather than the Simcard.... but a friend who is much more computer literate than I is the one that did it, so it's completely possible. I'm sure Sporty Bob can get you the info you need.
  1. Runtime error
    By mstreur in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-09-2014, 07:26 PM
  2. Coreldraw X4 and Lasercut 5.3 runtime error 429
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-02-2014, 09:05 AM
  3. v-25 demo runtime error
    By 1234567 in forum BobCad-Cam
    Last Post: 05-29-2012, 11:39 PM
  4. Runtime error
    By ARHEA in forum EnRoute
    Last Post: 05-17-2012, 06:43 PM
  5. Runtime error
    By msme-lc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-30-2008, 10:14 PM
