Originally Posted by
lcvette
I purchased the deepgroove probe and would not recommend it, as it lacks any adjustability. I think most any of the probes in this range are very similar. A few things I would consider while deciding on a probe are as follows:
- Metal body, preferably steel/stainless
- Adjustability, it is only accurate if it is centered and perpendicular to the work piece. Most of the better probes have two adjustments, one for concentricity and one for stylus perpendicularity.
- I would not get a skinny shank probe, to easily bent, 3/8" or larger would be my suggestion. Larger the better in my opinion.
- Make sure any probe you get has replacement parts available, you will undoubtedly have an "incident" with it and will need to make repairs when that happens.
- Accuracy, even my probe with some tweaks to align it would hold repeatability to .0002" when calibrated properly. This is tested on a per use basis with a round or square calibration block before any important probing operations.
- My personal preference is a probe with a plug in lead on the probe itself so it can spin freely in the spindle during calibration for centering. It is very difficult with a non removable cable.
Also go ahead and purchase an extra stylus or two as they have a tenancy to get bent during incidents.
I would also either find one with a good case for when not in use to keep it safe, definitely don't want it out where it can fall or get jostled around.
Hope that helps!
Chris
