Hello,
I would like to build a fixed-gantry, moving-table router. I am looking to get a 12"x12"x4" work envelope. I plan on using a set of of linear motion/bearings (SBR16,RM1605 and associated components).
Before I do anything, I would like to answer a very basic design question: How to determine the location of the linear rail nuts (SBRUU) to give the required travel distance on the Z-axis while keeping the overall height at a minimum. I tried to follow this guide Building a CNC Router Step 4: The Z-axis assembly but could not come to any concrete numbers. Also, how can I calculate the z-axis mounting plate dimensions (the plate where the router will attach to). Probably same goes for the Y-axis.
Basically, what method to follow in order to come up with the geometry and dimensions for a given work envelope.
I could go out an buy a ready-made kit like a Shapeoko or something similar, but I would rather build my own. I believe it will be better in terms of rigidity and accuracy. I have a welder and will use 1"x2" tubing for the frame. Just need to decide on the dimensions.
Thanks for the help in advance.
