Sino water jet cutting machine SN1020 is suit for cutting marble,stone,granite,ceramic,glass,stainless steel and other hard metarials.It is widely used in marble mosaic,glass cutting,metal cutting industry.
Water jet cutting machine SN1020 is equipped with cantilevered platform.it is more convenient to load/unload workpiece.and suitable for 3 directions loading.lt avoid the limit of gantry type which can only load on ends of Y axis.
The cantilevered platform can save space and easy to maintenance.More,it save one side parts of Y axis.so with lower price than Gantry.Cantilevered platform is more suit for worktable less than 2000mm width.
Feature of CNC waterjet cutter SN1020:
1,Special protective cover design which makes the machine more durable and with beautiful appearance.
2,Japan yaskawa/Panasonic servo motor and imported transmission guide rail with accurate positioning and smooth operation,ensure the accuracy in processing.
3,The working size and worktable can be made according to customers’ order. Non-standard platform and tools are available.
4,IPC control based on Windows,friendly and easy to operate.
5,Recommended-- Cantilevered glass marble granite stainless steel metal waterjet cutting machine platform is save space,practical and economica.
Parameters:
Model
high pressure abrasive cnc waterjet cutting machine SN1020
Processing size
X-aixs:2000mm Y-axis:1000mm Z-axis:150mm
Structure type
Cantilevered cutting platform
Pressure
380/420Mpa UHP pump
Main Motor
30kw or 37kw
Cutting precision
0.1mm
Power supply
380V/50HZ
Repeat positioning precision
0.02mm
Max. Traverse speed
10m/min
Transmission
Imported zero clearance ball crew and line rail imported from Taiwan.
Cutting Precision
0.1mm,
0.02mm
Drive motor
Japan YASKAWA AC servo (Ac Motor)
Lubricating
Auto concentrate lubricating system
High-pressure Intensifier
USA impprted
Water cooling system
Imported circulating water cooling system.
Water tank
High capacity hi-pressure water tank made of imported stainless steel.
PLC
Omron or Siemens
Waterjet cutting head
Orifice:0.17mm /0.25mm/0.30mm/0.33mm/0.36
CNC controller
Ncstudio system(English version)
