Hello,
Was curious if anyone here might have routed out some Lamboo.
Its a laminated veneer bamboo. See here: LAMBOO® Architectural and Structural - Engineered Bamboo Technologies
Not sure if there is any other similar type panels under a different name.
Attachment 262246
Problem:
we need to route thru this 3/8"th material to accept 3/4"th Clear Acrylic that
will be pushed thru w/ a shoulder from behind.
Letter height between 3-7" (varies per letter). The Lamboo is just the background.
Could anyone recommend a bit to use for this. Some corner areas need to go as
small as 1/8" dia. Obviously avoiding splintering.
Would be appreciated to anyone who may have experienced this type of material
and could share some good advice. Bit size, speeds etc.
Thanks for your time.
Ronnie
