584,846 active members*
4,153 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Foam works cutting speed problem
    Feb 2008
    20
    Question Foam works cutting speed problem
    Hi
    I have a 4 axis table that I built a number of years ago which I pulled out of moth balls. I am trying to get running again. I have a new computer and stepper motors and the break out board and stepper drivers are new
    I can get the mc to run, but it cutts at 0.6 mm/s and the hot wire even when turner down creates a huge kerf
    I have tried to change the steps per mm but end up with a wing that either is tooo small or one that will cut right though the end of the foam blank with the old set up it worked pefectly so now I am really confused.
    If I run Mach3 the steppers seem to run at the correct speeds.
    I would welcome a few suggestions.
    Neville
    Feb 2008
    20
    Re: Foam works cutting speed problem
    Solved the problem I built a new Belt driven 4 axis hot wire wing cutter here is my cutters first run.
    https://youtu.be/uVNOJgPmlns
    Apr 2007
    36
    I don't have foamworks, but what's happening is almost certainly problems with the software setup.
    Try running the cut at a constant speed- steps/second and use a separate power supply for the wire. Unless you are trying to do a lot of production there is no need to run the wire hot and fast. The slowest speed and the lowest temperature that doesn't put unwanted curves into the wing usually gives the best cut. Any tapered wing will always have a problem that the tip tends to get over heated. You can correct this by adjusting the coordinates of the areas that get overmelted,.
    Feb 2008
    20
    Hi Phil c
    Thanks for the help I am now running GMFC Pro and am having no problems at all although the foam works still has its uses and if I could get it to run on a USB port I would use it more as my computer which had a parallel port on it died
  1. RCH2030 CNC Cutting machines /Chinese cutting machine for foam
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 12-25-2014, 07:58 AM
  2. Mildly simple foam cutter works like a charm so feel free to copy it.
    By tommylight in forum CNC Wire Foam Cutter Machines
    Last Post: 09-14-2014, 10:33 AM
  3. Mach 3 Speed Issue on four axis foam cutting setup!!
    By Domdonder in forum CNC Wire Foam Cutter Machines
    Last Post: 04-01-2014, 02:02 PM
  4. Seeking perfect speed and temp for foam cutting
    By johnono in forum CNC Wire Foam Cutter Machines
    Last Post: 02-02-2009, 07:09 AM
  5. Looking for cutting speed and feerate data in wood and foam
    By Trimix in forum DIY CNC Router Table Machines
    Last Post: 01-21-2004, 03:20 AM
