Eric, can you tell me the pin outs for the touch probe and start stop switch for the Techno pci servo board riser card?
I will get this for you shortly.
Eric Feldman - Design Engineer, Programmer
Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
Hello,
pin 14 is gnd
pin 2 on the straight end connector is the probe
pin 6 is pause on the bent end connector
pin 8 is start on the bent end connector
Send me an image if you want us to check it out before you power up.
Use at your own risk and BE CAREFUL.
Eric,
Thanks.
