585,997 active members*
4,793 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > OK I can't find the problem gremlin and it's driving me crazy...
Results 1 to 5 of 5
    Dec 2014
    Hello Everyone!
    I would appreciate some guidance here...
    I purchased a 3 axis HobbyCNC EZ Rev0 Chopper driver board and soldered it together. Tested voltage as per instructions and its correct.
    Power supply is a Meanwell NES 350-24v with 14.6 amps output
    I am trying to run 3 Powermax II P22NRXG-LNN-NS-00 stepper motors
    My computer is a Windows 7 machine and did not come with a parallel port, so I purchased a PCI-E 1284 DB25PIN card and installed it. I also purchased a cable and tested it for continuity with my multimeter, the pins are indeed straight-through (some posts suggested weird wiring inside the cable could cause issues)
    I have the 8 wire motors wired up as:
    B - blue
    b - orange
    COM - 2 black wired into one COM terminal
    COM - other 2 black wired into other COM terminal
    a - red
    A - yellow
    Using Mach 3 I have the Ports & Pins setup as:
    X axis pins 2, 3
    Y axis pins 4,5
    Z axis pins 6,7
    Everything else I can see is set to Pin 1.
    I plug this baby in, turn it on and I cannot seem to get anything to happen. No noises, no nothing.
    What simple but painfully obvious step have I missed here?
    I appreciate your help!
    Mar 2007
    2083
    Re: OK I can't find the problem gremlin and it's driving me crazy...
    Hi Dakk
    with the power on are the motors locked in position ?
    if the reference voltage on pin 13 is over 2v or none of the mode jumpers are fitted the stepper driver IC goes into sleep mode
    a while ago I tried a printer port adaptor in a PC but I could not get it to work
    from what I understand not all IC's used in the adaptor cards work with Mach 3
    you could try building this tester from Geckodrive.com :-
    Attachment 262582
    It could make it easier to prove the HobbyCNC board is working
    without a logic probe it can be difficult to test the step pulses from the printer port
    you will not se them with a multimeter
    John
    May 2009
    36
    Is the address of the card correct and the same in M3?
    Mar 2007
    2083
    since the mother board had no on board port I set the adaptor to 0378 hex ( mach3 default address)
    15362
    Dakk
    Mach3 does not support a Parallel Port in windows 7 64bit, you will need a UC100,or a Smooth Stepper Etc to use Mach3 with windows 7, I have seen others have the same problem using windows 7 with trying to use a Parallel Port
    32bit can work with a Parallel port but if you have 64bit it is not going to work
    Have you checked the output from the Parallel port
    Mactec54
  1. PLZ HELP!!! Probotix driving me crazy!!
    By Blairfab in forum Community Club House
    Last Post: 11-07-2013, 03:14 AM
  2. blackouts are driving me crazy!!!!
    By carlo mateo in forum Safety Zone
    Last Post: 01-23-2013, 05:00 PM
  3. Protel is driving me crazy
    By ez-cnc.com in forum CNC Machine Related Electronics
    Last Post: 03-30-2010, 06:54 AM
  4. Gcode its driving me crAZY
    By frankg521 in forum G-Code Programing
    Last Post: 09-20-2007, 01:17 AM
  5. Aligning cross table is driving me crazy. Ideas?
    By pigifly in forum Uncategorised MetalWorking Machines
    Last Post: 07-07-2004, 08:45 AM
