Need some help diagnosing a jagged edge on cuts diagonal to the x and y axis. I am getting clean cuts parallel to each axis but when cutting at an angle I get chatter. I am not sure if this is a rigidity or a drive problem. The machine is home built with cncrouterparts rack and pinion and rollers on the x and y axis and profile rails and ball screw on z. I am driving everything with a Gecho 540 and Mach 3. Everything seems tight. The sample pics were cut with a new 1 flute downcut spiral, 180 IPM, 20,000 RPM, climb rough pass with conventional cleanup pass. Any thoughts would be appreciated. Long time reader first time poster
