Howdy,
I've been building my CNC Router (an Ox variant) and I've gotten it all up and running and cut a few things, but I'm having a hard time getting it calibrated correctly. I'm using Mach3 and CamBam and I've done the motor calibration bit over and over and I'm certain it's right, but every time I load a gerber file from CamBam into Mach3, Mach3 renders it at around 10 times the specified size. (It does the same thing with LazyCam too). I'm working in Millimeters ('mm') in all my programs. I have Mach3 units set to 'mm' and all axis calibrated in 'mm'. My CamBam drawing is also set in 'mm' and exported to gerber, presumably in 'mm'. But Mach3 keeps reading it and rendering it as if it's in Centimeters (cm). I have searched all the CNC sites and simply cannot figure out for the life of me what I'm doing wrong. I've looked on Google and have seen a few other people having similar issues but nothing that seems really clear and definitive as to what is happening-- is it supposed to be 'mm' but actually interpreting it as 'cm', for instance? I dunno...
Is there anybody here who could help me figure it out?
Thanks!
John
BTW Just to be clear, this is how I'm doing the calibration. I have the 'motor units' set to 'mm', and verified in the Settings page. Then, on the Settings page, I'm using the auto-compute axis button to calculate the right motor values based on measured travel. When it prompts me for a distance, I enter it in millimeters (such as '10') and expecting it to travel 10 literal millimeters-- NOT centimeters! For more accuracy, I generally do it several times and have it travel further each time, like out to the end of the table in millimeters (e.g., '1,000' millimeters). I also test it backwards to make sure it travels the same distance in both directions.
Here are links to the photo / video stream of my project if anybody's interested:
Photos:https://plus.google.com/u/0/photos/1...81671319135809
Videos: https://www.youtube.com/playlist?lis...-XqtrCqmyk6Sq-
