Hi all,
What I need is a cnc machine which scores glass. I'll be using it to cut stained glass, which is uneven, so the scoring tool will have to be spring loaded. And ideally, I'd like it to have the option of being able to change tool automatically with one other tip. Size: the cutting bed should ideally be able to handle 1200mm x 850mm sheets.
I'm asking in this forum if there's anything anyone makes specifically for this job, but I'll also be posting in the DIY section in case I have to build it myself.
Any advice is well appreciated.
