585,712 active members*
4,007 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > No feedback from encoder on a 320x
    Jul 2014
    39
    Hi
    I got my x and z Gecko 320s working no problem. For the panel rebuild I purchased a new G320x for the Y axis.
    I used the same wiring as the 320s but it seems the motor ran away. Not a big deal since I made
    certain the timing belt wasn't attached. I have the US Digital E2 with differential encoder cables. So at this
    point the Gecko isn't recognizing the encoder I assume. I`m using all the default settings at the moment.
    I tried using the HED dip switch setting but still the motor just ran at full speed. Gecko has a known problem
    with the US digital encoders. But various people have mentioned if you have line drivers the encoders should
    work. Is there any difference in the wiring from a 320 to 320x. Checked out both manuals to my eye they look
    the same.
    Jul 2014
    39
    Re: No feedback from encoder on a 320x
    Hi
    This is embarrassing. The encoder cables were not completely seated.
    Now its working.
    Please see the HEDS modification application note on the G320X product page.
  1. Encoder/feedback unit fg n tg?
    By integerspin in forum Servo Motors / Drives
    Last Post: 11-27-2014, 07:43 PM
  2. 320x encoder power limitations
    By GT390 in forum Gecko Drives
    Last Post: 09-04-2012, 11:13 PM
  3. gecko 320x maxon encoder issues
    By airdamien in forum Gecko Drives
    Last Post: 07-01-2012, 03:03 PM
  4. Emc2 with encoder feedback
    By R.thayer in forum LinuxCNC (formerly EMC2)
    Last Post: 01-27-2007, 04:26 PM
  5. g-rex and encoder feedback
    By davidp in forum Gecko Drives
    Last Post: 04-24-2006, 11:22 PM
