586,000 active members*
5,016 visitors online*
Results 1 to 9 of 9
    Feb 2011
    212
    connectiong 2 computers
    I have a laptop that I make all my programs on and then put programs on USB then upload them on my computer that has Mach 3.
    My Question is can I use a network cable to connect the 2 computers and simply map a drive and drag and drop the programs ?
    any and all help is appreciated
    Jul 2015
    5
    Re: connectiong 2 computers
    Don't know if you are still working on this but...there are a few ways to do what you would like. First off, we will need to know what you are running for software on both computers and if both computers have a way to connect: parallel port, serial port, network cables, etc.
    Hope we can help...
    D
    Jun 2005
    1730
    Learn,
    This is very easy to accomplish if you have a network with a router just plug in both computers to the router and turn on sharing for both computers. If you have no network or router available you can still connect the two computers using a direct connection. This require a null modem type networking cable where some of the wires are reversed, they sell these at computer stores they are very common. If you have that cable you plug one end into each computer, now since you do not have a router there is no IP address assigned by DHCP, so you have to go to the networking tab and assign a static IP address like 10.168.1.2 and 10.168.1.4, then you must reboot the computers when they come up again they will have a static IP address. Now you turn on sharing and you will be able to see both computers and move files between them over the network link. Honestly, you might want to buy a cheap router and even do this wirelessly without any cables. You do not need a internet connection but a router would eliminate the need for setting up static IP address and the need to make changes each time you wanted to use those computers to access the internet.
    Russ
    Feb 2011
    212
    on my mach 3 computer it is windows XP
    my other computer is my laptop and it is running windows 8
    Jun 2005
    1730
    Learn,
    Can can still connect the computers with XP and Win8, you did not say if they had a network between them?
    Russ
    Feb 2011
    212
    No network in the garage. I do have an old router but I had no luck trying that
    Jun 2005
    1730
    Learn,
    My advice would be to buy a cheap 2.4GHz wireless router, do you have a wireless card in the computer in the garage? If not they make cheap cards or small USB dongles that provide Wireless connection. The wireless approach is the easiest thing to do and some of these wireless routers are $40 at local computer stores like MicroCenter, Fry Electronics, etc. Once you have the computer so it can talk to the router the rest is simple. Just turn on sharing and you can setup a folder to move files.
    Russ
    Dec 2007
    2134
    A lot of the wireless routers now support USB drives or keys, so this would make it much easier to share files from one location to another without enabling shares on machines.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Jun 2005
    1730
    Learn,
    aarggh is correct the latest set of wireless routers have the feature to share a USB stick, however you can share the directory where you process your file with your CAM tool as well.
    Russ
  1. What Computers do I need
    By paulkane1 in forum Controller & Computer Solutions
    Last Post: 12-11-2012, 08:04 AM
  2. Connectiong Bob-Cad/CAM to a DM2400?
    By tomcat in forum BobCad-Cam
    Last Post: 10-02-2010, 10:16 PM
  3. Mac computers
    By larry53 in forum Computers / Desktops / Networking
    Last Post: 03-20-2010, 08:28 AM
  4. Uses for Old Computers
    By Too_Many_Tools in forum CNC Machine Related Electronics
    Last Post: 06-23-2006, 05:23 PM
  5. TIG and computers
    By nervis1 in forum Welding Brazing Soldering Sealing
    Last Post: 06-27-2005, 07:25 PM
