585,996 active members*
4,664 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > 4 Axis Mach 3 Postprocessor (free but kinda wip)
Page 5 of 6 3456
Results 81 to 100 of 104
  1. #81
    Jul 2016
    Re: 4 Axis Mach 3 Postprocessor (free but kinda wip)
    HELLO.I AM KHELAF.HAVE IDEA ABOUT CAMWORKS
  2. #82
    Aug 2016
    6
    hell o guys,
    is there a post process for alphacam that can run the four axis on a mach3 program
    thanks a lot.
  3. #83
    Jun 2004
    8
    Hello everyone
    I use SC2012
    Can not see the GPP file in the table
    can get help Please?
    Thanks in advance
    Yoram
    Attachment 336688
  4. #84
    Oct 2016
    25
    Hello,
    i have created a SolidWorks File for my CNC Router 3040T and did not know how to create the Maschine Simulation?
    Can anyone help how to create the XML-File?
    Matthias
  5. #85
    Jun 2014
    18
    Quote Originally Posted by y_shalom View Post
    I use SC 2012
    I think it's gluck of SolidCAM.
    I have deleted all unnecessary files in my SolidCAM2015 (~270 files *.GPP,*.PRP,*.VMID).
  6. #86
    Jan 2017
    13
    Hi guys,
    first of all: AMAZING WORK and thanks a lot for doing this. Big thanks to Jailbreaker how's post processor I'm using now.
    I have tested the post processor on a 3 Axis Machine and had some issues with the Spot and Deep drill operations.
    Might be a setting in mach3 that I missed? If it is a stupid question please forgive me. Quite new to this.
    Spot Drilling will output the following code:
    ( 4-SPOT DRILL - DRILL )
    G0 X23. Y9.615 Z10. A0.
    G82 Z-2.79 R0.21 P0 F200
    X40.2 Y9.615 Z0.21
    X57.4 Y9.615 Z0.21
    X74.6 Y9.615 Z0.21
    X91.8 Y9.615 Z0.21
    X109. Y9.615 Z0.21
    G80
    ( ---- End of 4-Spot Drill ---- )
    Mach 3 (at least mine) does the first hole as planned but then moves to hole 2 at height 0.21 only, does not spot drill and move on to the next holes.
    Same effect with deep drilling:
    ( 5-4.2MM-DEEPDRILL - DRILL )
    G83 Z-7.732 R0.21 Q0. P0 F200
    X40.2 Y9.615 Z0.21
    X57.4 Y9.615 Z0.21
    X74.6 Y9.615 Z0.21
    X91.8 Y9.615 Z0.21
    X109. Y9.615 Z0.21
    G80
    ( ---- End of 5-4.2mm-DeepDrill ---- )
    I manually edited the code to add the G83/G82 string after each re-positioning move and it works fine after that.
    Did I do something wrong?
    Thanks !
  7. #87
    Aug 2013
    189
    probably you are because I use this post processor for some time for both 3 and 4 axis and drilling has no problems at all.... I use all drill cycles (mostly g83) and absolutely no problems, in fact I was working on the post processor with jailbreaker (mainly testing for bugs and errors) and drilling was tested to the limit and all works nice. maybe you should upload your part and cam file so I can take a look.
    for exemple this is a drill code generated from a file of mine, drilling 9 holes using peck drill G83:
    O5000 (10XC22)
    ( --- Initialisation --- )
    G0 G40 G49 G80 G21
    G0 Z10.
    G0 A0.
    G54
    (Tool # 1 - Diameter 3. D1 H1)
    S1000 M3
    M8
    G54
    ( 1 - DRILL 3MM - DRILL )
    G0 X5. Y5. Z10.
    G83 Z-25.901 R2. Q5. P0 F500
    G0 X109.499
    G0 X213.999
    G0 Y158.996
    G0 X109.499
    G0 X5.
    G0 Y312.993
    G0 X109.499
    G0 X213.999
    G80
    ( ---- End of 1 - drill 3mm ---- )
    M9 M5
    G0 Z10.
    G0 A0
    M30
  8. #88
    Jan 2017
    13
    Ok. Thanks for the reply.
    This is very interesting. I thought I have an issue with Mach3 but this points towards a setting in SC.
    I went through all the SC settings and also checked the coordinate system but I can't find a setting that will change it :-(
    I also noticed that your gcode does not have the homing commands at the beginning and end like mine (G53) - which I'm also trying to find a way to get rid off (besides removing it manually afterwards).
    Are you using the latest version of the post processor from github? (https://github.com/teodoryantcheff/SolidCam-Mach3-Post)
    Could you post your version here? Maybe there is a difference in the files.
    Any other advice you can give me?
    Any help is highly appreciated.
    Here is the full gcode I get when I run a G82 operation with the github Mach 4 Axus X and Y post processors:
    O1000 (TOP PLATE_MILLING)
    G17
    G0 G40 G49 G80 G21
    ( --- Go To Machine Origin --- )
    G0 G53 Z0
    G0 G53 X0 Y0 A0
    G54
    (Tool # 301 - Diameter 2.78 D301 H301)
    T301 M6 D301 H301
    S3500 M4
    M8
    G54
    ( ---- Start of N3 Center Drill ---- )
    G0 G53 Z10 ; move up to tool_z_level
    G0 G53 A-0
    ( N3 CENTER DRILL - DRILL )
    G0 X21. Y16. Z6. A-0.
    G82 Z-3. R1. P0 F200
    X11. Y20. Z1.
    X53. Y16. Z1.
    X106. Y20. Z1.
    X106. Y63. Z1.
    X11. Y63. Z1.
    G80
    ( ---- End of N3 Center Drill ---- )
    G0 G53 Z0 M9
    G0 G53 X0 Y0 A0 M5
    M30
  9. #89
    Dec 2014
    14
    I have been using "johnMill" postprosessor now roughly for 2 years with my Chinese X6-1500GT-USB. Few items what I have found to be problem for this particular motion card:
    -G54 at start of file or separate operation => Mach3 assumes G54 in use if not changed to other. My motion card gets confused (G54 in use and told to use G54 again) and randomly loose coordinates, depending on motor tuning it is either Z, X or Y. Removed G54 from postfile and now works without problems.
    -Drill operation: at the beginning of this thread I wrote my drill problems. Solution was to un-tick "use cycle" in drill technology page, it is typically selected by default.
    Postprosessor is easy to tweak once you find it and use common sense (removing G53 X/Y is simple, you can add delay after M4 etc).
    My G83 cycle looks now this:
    O1 (LYMANBARREL12.00_MILLING)
    N5 G0 G40 G49 G80 G21 (Initialisation)
    N10 G0 G53 Z0 (Go To Machine Z Origin)
    N15 (Outil n° 10 - Diametre 3.0 D10 H10)
    N20 M9
    N25 T10 M6 D10 H10
    N30 S5000 M4
    N35 G4 P3000
    N40 M8
    N45 (D-drill2)
    N50 G0 X5. Y6.25
    N55 G43 H10 Z35.
    N60 G0 Z7.05 A0.
    N65 G1 Z4.35 F25
    N70 G0 Z7.05 A0.
    N75 G0 Z6.35 A0.
    N80 G1 Z3.65
  10. #90
    Jan 2017
    13
    Update to my post above: using the dev post processor in github has fixed my drilling issues. Now I just need to get rid of the tool change at home position entry which I guess is a setting in SC.
    Thanks guys, awesome work.
  11. #91
    Jun 2017
    i want 4 Axis fanuc post processor
    can upload it for me?
  12. #92
    Jun 2017
    i need it
  13. #93
    Apr 2017
    wow,that is great,thanks very much!
  14. #94
    Oct 2016
    25
    Hello,
    if i understand all right i should use the "PostDevTestMachine" gpp in Solidcam?
    But i can not find that file on github.
    Which one should i now use?
    Matthias
  15. #95
    Feb 2019
    6
    Thanks for all your helpful tips.
  16. #96
    Jun 2020
    Hi, thank you very much for this topic!
    I use a machine with 4 axis DSP A18 controller.
    downloaded the postprocessor and the machine file from the theme to the github, installed under the solidCAM 2020.
    Successfully made a set of gears in 4-axis rotary machining.
    Now I’m trying to do 5 axis processing with locked 5 axis, the code generates solid and everything is fine, but after the postprocessing the control program does not work correctly.
    Please tell me what could be the matter?
    the axis of the machine rotates around Y
  17. #97
    Dec 2010
    32
    this is what cnczone is giving me. No idea what the attachments should be.
    Also, very little of what you said makes sense for a 5 axis machine....
  18. #98
    Apr 2012
    5
    Quote Originally Posted by sssMOsss View Post
    wow?that is great?thanks very much?
    Hello,
    I'm trying to use my 3040 4 axis machine and I was hoping if you guys can help me with post processor file.
    I'm using SC and Mach3
    Thanks in advance
  19. #99
    Mar 2019
    27
    Hi
    do u have this post for alphacam??
  20. #100
    Dec 2010
    32
    Well, the answer to your question is in the thread's title... only solidcam...
Page 5 of 6 3456
  1. Postprocessor Camworks to Mach 3
    By mazaracing in forum CamWorks
    Last Post: 02-11-2011, 10:29 PM
  2. 5th axis kinda
    By Delw in forum Haas Mills
    Last Post: 12-14-2010, 03:37 PM
  3. Mach 3 Postprocessor for SolidCam
    By Debos in forum Screen Layouts, Post Processors & Misc
    Last Post: 06-20-2008, 11:15 PM
  4. 2UVR x-axis powerfeed sorta kinda working
    By Stinson_Voyager in forum Tree
    Last Post: 01-14-2007, 08:11 PM
  5. 2UVR x-axis powerfeed sorta kinda working
    Last Post: 12-27-2006, 06:10 PM
