585,997 active members*
5,187 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Charmilles Robofil 400 error E02 P01 ? while cutting.
    Jun 2009
    11
    I've had this machine for 15 years and it has been great. Recently when I'm cutting the generator, motion, and fast cut pump will shut down but the wire will continue running. Control pad is non-responsive except the power button. The screen shows E02 P01 ? at the bottom and I'm pretty sure that's a power issue. I checked my line voltage it's 244vac, rear of front panel voltages are 4.98 -11.94 11.99vdc. I sent an email to Charmilles tech but thought someone here might have the answer before next week. As it stands I have to monitor it while running because it will run the wire thru the machine until I power cycle it.
    Thanks in advance,
    John
    Sep 2012
    15
    Christeon
    I have a Robofil 200 and having the same problem. After loading the Communication disk the screen goes blank with this message E02 P01 ? at the bottom. Is this related to 24volts output. Have you found the solution to this problem. If so please pass on the details.
    Thanking You
    Yogesh.
  1. error starting up a charmilles robofil 299
    By carlos1989 in forum Waterjet General Topics
    Last Post: 08-28-2020, 10:26 PM
  2. Charmilles Robofil 290P with system error
    By Musea in forum EDM Discussion General Topics
    Last Post: 05-14-2014, 06:24 AM
  3. DNC CHARMILLES ROBOFIL 310
    By tecnomaqq in forum EDM Discussion General Topics
    Last Post: 01-17-2014, 04:34 AM
  4. charmilles Robofil 190 or charmilles Robofil 290
    By Fontez in forum Post Processors for MC
    Last Post: 03-12-2013, 04:48 PM
  5. Charmilles Robofil 310 disk format error
    By ecduplex in forum EDM Discussion General Topics
    Last Post: 12-06-2010, 09:50 AM
