585,604 active members*
3,419 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Collisions in simulation
    Jan 2012
    222
    Cool Collisions in simulation
    Hello!
    I have a test model of a simple box with lid. As the cut progresses it collides with the stock outside of the curve I defined as the limits. I have had this problem before but I forgot what I did to eliminate the cuts outside of the curve I set as the limits. Can somebody take a look at what I am doing and give me some pointers as to keeping the cuts inside of the limits curve?
    The cutter is in imperial and is 4" long, 1.25" cutting length, .25" diameter flat.
    thanks!
    Jan 2012
    222
    Re: Collisions in simulation
    Well, I got what I wanted but is it the right way to do it?
    Anyways, I remember faintly that this was how I did it before... see attached.
    Mar 2004
    1661
    Without looking at the model, Region curves doesn't fence of the cutter. It only says "cut this region". An easy way to really fence off the cutter is to extrude the region curve upwards, include it in the MadCAM work boundary box, set the region curve and a clipping plan lower than the extruded curve. Now the cutter will stay inside the extruded surface, which is acting as a real fence.
    MADCAMCNC: Region curves vs extruded curve
  1. Replies: 2
    Last Post: 07-30-2014, 05:27 AM
  2. Rapid collisions
    By MitchB in forum MadCAM
    Last Post: 12-18-2013, 11:49 AM
  3. Simulation Done Right
    By jrmach in forum BobCad-Cam
    Last Post: 04-18-2013, 03:05 AM
  4. v25 Simulation
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-15-2013, 09:38 PM
  5. Torch collisions
    By plain ol Bill in forum Waterjet General Topics
    Last Post: 07-23-2009, 08:22 AM
