585,568 active members*
3,302 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > The Nomad 883 and Post Processors
    Jan 2015
    Will Sharpcam be supporting the Nomad 883 when it is available? Which machines do you have post processors for? I'm looking at CNC machines and CAM options for producing jewellery and I need a CAM system which is both accurate and highly efficient.
    Re: The Nomad 883 and Post Processors
    Thanks for your question. We do plan on supporting the Nomad 883 when it is released. Sharpcam has post processors for all major machines, including Fanuc, Heidenhain, Haas, Fadal, Siemens, Mach3, Anilam, MILLPWR, ProtoRAK and WINCNC. Our Post Processors are very configurable, so for example, our Fanuc post will work with most machines fitted with a Fanuc. If the post is not available, then the "Machine Developer" can be used to edit existing posts or make brand new ones. This is a straight forward process, however to make this even easier, we do offer a free post creation service to all our customers.
    You can download a free demo version of Sharpcam at SharpCam Ltd | Download Request. We can also offer a free live online demonstration with a Sharpcam engineer. Further info at CAD/CAM Software | CNC programming systems | SharpCam Ltd
    Thanks for your question. We do plan on supporting the Nomad 883 when it is released. Sharpcam has post processors for all major machines, including Fanuc, Heidenhain, Haas, Fadal, Siemens, Mach3, Anilam, MILLPWR, ProtoRAK and WINCNC. Our Post Processors are very configurable, so for example, our Fanuc post will work with most machines fitted with a Fanuc. If the post is not available, then the "Machine Developer" can be used to edit existing posts or make brand new ones. This is a straight forward process, however we do offer a free post creation service to all our customers.
    You can download a free demo version of Sharpcam at SharpCam Ltd | Download Request . We can also offer a free live online demonstration with a Sharpcam engineer. Further info at CAD/CAM Software | CNC programming systems | SharpCam Ltd
  1. Post processors....
    By jame5m28 in forum Uncategorised CAM Discussion
    Last Post: 02-19-2024, 01:07 AM
  2. Nomad 883
    By metalfixer in forum Uncategorised CAM Discussion
    Last Post: 12-15-2014, 02:02 PM
  3. What are 'post-processors'?
    By Countryman in forum Uncategorised CAM Discussion
    Last Post: 07-15-2009, 12:55 PM
  4. post processors
    By Turn Man in forum Uncategorised CAM Discussion
    Last Post: 05-30-2004, 07:13 PM
