Originally Posted by
popspipes
I have done this in sprut 7.
I just select the model and move the Z axis of the part in the locate zero tab up enough to clear the new part, then import the new part, then select the old part and delete it. Then all the holes and other machining ops have to be reselected, this usually works but not always for me.
I find it easier to save all the ops of the old part using the "save as default parameters" in the right click dropdown menu on each op. This saves all the parameters of the op so there is less chance of making a mistake.
Then import a new model of the changed part and and reimport the ops as "load from default parameters" line in the right click on the op menu.
The bummer is you have to respecify the ops again before you can import their values into the respective ops.
I sometimes take a snip of those (windows desktop) and recreate the ops again in the new machining tab using the info off of the snip.
I do this quite a bit as I am always changing the part or updating it.
I imagine this procedure will work in the newer sprut versions as well.
