585,741 active members*
4,992 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Plasma, EDM / Other similar machine Project Log > Anyone tried the THC3T-03-Stand-Alone-Plasma-Torch-Height-Controller
Page 3 of 3 123
Results 41 to 43 of 43
  1. #41
    Feb 2011
    36
    Re: Anyone tried the THC3T-03-Stand-Alone-Plasma-Torch-Height-Controller
    I think to add Puddle jump future to the simplicity controller too.
    Other Neuron controllers works only with Mach3/4 CNC software. And for Start/Stop signals for Mach3 we have 25 msec max delay, for Mach4 10 msec (plugin loop timing). This value is too large for synchronous Torch on/off switching (especially for high cutting speed).
    Hold input have 5 msec delay on all controllers. All controllers has hole centre marking future.
    Just a lot of future are not described in the user manual, because this is embedded part of the cutting process, which determine how the system will behave in different situations without any human intervention.
    Best Regards!
    Andrew.
  2. #42
    May 2016
    Quote Originally Posted by ozyjimbo View Post
    I have the thc3t-04 and have been impressed with it so far takes a little to configure but once done works like a charm cheap yes works yes and have had plenty of support from the company
    It's an old thread, but you seem to be happy with the: thc3t-04 If you have any information on setting the thing up I would appreciate oyur input, I want to buy the same version, the one that is stand alone. 250. Sounds great. Any information would be great, Thanks in advance!
  3. #43
    Jul 2014
    19
    about the only problem i had was with the torch height sensor apart ftom that it was pretty easy to setup but if you are looking for a budget thc check out the mini thc i have one and it's great
    https://www.ebay.com/p/Minithc-Unive...thC/1337949302
Page 3 of 3 123
  1. latest plasma torch height controller (demo vedio)
    By larryy1022 in forum News Announcements
    Last Post: 06-19-2011, 01:33 PM
  2. Replies: 0
    Last Post: 06-08-2011, 02:36 PM
  3. stand alone arc voltage torch height controller update
    Last Post: 10-16-2010, 10:46 AM
  4. help stand alone torch height control needed
    By marcmnrsports in forum Waterjet General Topics
    Last Post: 01-16-2008, 12:59 PM
  5. RoboTorch Automatic Plasma Torch Height Controller
    By Dennis Bohlke in forum News Announcements
    Last Post: 08-24-2006, 06:58 PM
