585,762 active members*
4,085 visitors online*
    Dec 2012
    12
    Need help find data for motor
    Looking to build a 4th axis for my Bridgeport and have a motor in my scrap box. But i need to find data and have no luck so far. Can somebody please help me? Came up with this so far. file:///C:/Users/User/Desktop/ELec_0644.pdf
    Dec 2012
    12
    Re: Need help find data for motor
    More pics.
    24220
    That appears to be an OEM motor so the numbers do not seem to jive with the catalogues I have, but it does appear to be a version of the ElectroCraft MAX-100 series, if you post the exact dimensions I may be able to match it in the cat.
    The Heidenhain encoder unfortunately lists as the 11µa output version, not the 5v TTL.
    You could try using an IC to square up the sine wave if you wish.
    Al.
    Albert E.
  1. Calculations to find stepper motor for 5th axis. What motor?
    By dfaszer in forum Mechanical Calculations/Engineering Design
    Last Post: 12-01-2014, 10:53 PM
  2. Looking for data on old stepper motor, and is it worth using ?
    By Kenneth Jensen in forum Stepper Motors / Drives
    Last Post: 06-24-2014, 10:32 AM
  3. Stepper Motor data needed
    By leitox in forum Stepper Motors / Drives
    Last Post: 06-27-2013, 02:49 AM
  4. ERROR Cannot find parasolid data in solidworks file?
    By blakemachine in forum Mastercam
    Last Post: 12-04-2010, 05:49 AM
  5. Stepper motor data for 4H5618S-69
    By Zeljkoc in forum Stepper Motors / Drives
    Last Post: 03-18-2010, 09:15 PM
