585,975 active members*
4,459 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Cutting 1/8" (3mm) acrylic with 80 Watt, power and speed suggestions
Results 1 to 7 of 7
    Sep 2011
    26
    So I finally have my x1390. Laser Engraving Machine - Low cost Laser Engraving Equipment System by Redsail
    A few questions.
    1. I'm using it to cut shapes out of acrylic, 1/8" x 32"x48" sheets. I'm just curious as to general power and speed settings to cut this acrylic. I've obviously played around with it and cuts decent, but I'm not sure what I should be looking for. Right now it seems like I need 80% power at a fairly slow speed to cut well.
    2. What is the recommended distance from the material should the laser sit. Right now its 15mm as recommended by the manufacturer, but seems high to me?
    3. This machine does not have a Z-Axis; trade off for getting a large machine for a good price. I need to shim the acrylic sheet up about 1" Just been messing around and have used wood temporarily. Would it be worth while to cover the wood with a thin sheet of aluminum or something so the wood isn't consistently burning
    Sep 2014
    128
    Re: Cutting 1/8" (3mm) acrylic with 80 Watt, power and speed suggestions
    eighth inch is about 3mm
    3mm acrylic will cut *beautifully* at 7 mm/sec and 30 watts on my machine with a 4" lens
    80% of 80 watts = 64 watts, so something *horrendously* wrong there, I cut 25 mm acrylic with 40/45 watts
    here is a vid of 3mm acrylic cutting
    Sep 2011
    26
    I have a lot of surface area to cover; i'm not super worried about the looks of the sides. I was previously using a router without any kind of finishing.
    I'm really new to lasers, Would it be bad to cut at like 100% power to find the maximum speed?
    Jun 2014
    611
    for our machine, if you use 80 watt laser tube, we suggest 15mm/s 60% power.
    and you can check the parameter from our website, download the data from our website directly, maybe it is useful to you.:violin:
    download - Thunderlaser
    vinyl1968 Guest
    What is the best cutting wattage and speed for cutting 12" vinyl records with the thickness 2mm ? 60 watt speed with 10mm speed ?
    Jan 2008
    940
    Quote Originally Posted by vinyl1968 View Post
    You don't vinyl records contain PVC that is a no no to cut with a laser
    I do my engravings at 45% power & 300mms on my 50 watt tube. It engraves about 1/2mm deep at these settings(which is too deep for what you want), just to give you an idea. I cut at 60% power & 6mms for a nice refined edge with a 1.5" lense(Focal point) with the convex side up at 4.5mm from nozzle tip to the acrylic workpiece. I do not reccomend using PVC for the obvious reason. Get black acrylic. Hope this was helpful.
    Sent from my SM-G935F using Tapatalk
  1. What causes "rough" edges when laser cutting acrylic?
    By shobley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2011, 12:19 PM
  2. Cutting 1/4" acrylic - perfectly perpendicular cuts possible?
    By jeanyes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2009, 11:53 AM
  3. New to cutting wood, need suggestions and Speed and Feed
    By Driftwood in forum CNC Machining Centers
    Last Post: 04-05-2008, 05:59 AM
  4. Cutting 2" cast acrylic
    By routski in forum Material Machining Solutions
    Last Post: 01-11-2008, 09:44 AM
  5. Power needed to cut 1/16" ABS and 1/8" Acrylic?
    By SRT Mike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-19-2007, 04:24 AM
