KL-6090 with Vacuum Table, 36 x 24 inch Working Size, Can Run at 110VAC or 220VAC
you can come to our show room to check the machine.
Click to Apply Financing
This machine runs at 110VAC or 220VAC, We add a step-up transformer, 110VAc to 220VAC (Optional add $100)
Brand New CNC Router Engraving Machine with Mach3 Controller, 2.2KW Spindle + 2.2KW Variable Frequency Drive
We Changed this Machine to Mach3 Controlled System.
Machine Size: 960 x 1320 x 1200 mm
Working Size X,Y,Z : 600 x 900 x 150mm ( about 24" x 36 " x 6")
Working Speed : 200 -300 IPM
Resolution: about 0.002"
Mach3 Controller with Mach3 Demo SoftWare
Spindle: 2.2 W, Water-Cooled, ER20 collet chuck
Water Pump With Tank
Spindle Speed: 0-24000rpm with VFD, AC220V/50Hz/60HZ
X, Y, Z axis driver: Stepper Motor Driver, NEMA34 Stepper Motor, 640 oz-in
Vacuum pump and motor are not included
X Axis: SFU1605-C7 high precision ball Screws, Anti-backlash
X Axis has linear shaft 20mm support
Y Axis: SFU2505-C7 high precision ball Screws, Anti-backlash
y Axis has linear shaft 20mm support
Z Axis: SFU1610-C7 high precision ball Screws, Anti-backlash
Z Axis has linear shaft 20mm
X, Y Z Limit Switch
6 Axis Breakout Board Optical Isolated
E- Stop
Wood Packing Size: 1380 x 1090 x 1400 mm
one year USA parts warranty
if you need more detail, check here
http://www.automationtechnologiesinc.com/products-page/cnc-router/kl-6090-with-vacuum-table
List Date: 1/19/2015
For more info, click here to view the original listing: KL-6090 with Vacuum Table, 36 x 24 inch Working Size, Can Run at 110VAC or 220VAC
On Sale For: $5,268.90 + $299.00 Shipping
Mobile friendly version: KL-6090 with Vacuum Table, 36 x 24 inch Working Size, Can Run at 110VAC or 220VAC
