585,970 active members*
4,363 visitors online*
    Jan 2015
    VSD-E USB Cable
    Hello!
    I am buying VSD-E and already have ordinary FTDI USB to Serial 232 6 pin Cable.
    Will this cable work with VSD-E or do I have to buy one from Granite Devices?
    Thanks, Franc
    Nov 2005
    12
    Re: VSD-E USB Cable
    Franc,
    Don't know if this helps, but the cable I use with my current VSD-E cards is marked TTL-232R-5V. 6 wires out.
    I
    Sep 2004
    1207
    Re: VSD-E USB Cable
    Any TTL-232R with 6 pin connector (5V model recommended, 3.3V probably will work too) will work.
  1. Microkinetics NM400E Cable SCSI50M to DB25M Cable Pin-Out
    By Contract_Pilot in forum Stepper Motors / Drives
    Last Post: 10-01-2014, 10:29 PM
  2. AC power cable in the same cable carrier with motor cables
    By bandtank in forum CNC Machine Related Electronics
    Last Post: 06-02-2010, 12:06 AM
  3. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
