585,717 active members*
3,916 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MASTERCAM X8 WCS PROBLEM
    201
    I am having a problem with the WCS in Mastercam. I set a new WCS and it will not stick. I did not have this problem with any other version of mastercam. If I us my spaceball to move the model around and the wcs switches on me. Is anyone else having this issue? Is there a setting that I am not setting?
    Dec 2008
    3109
    Re: MASTERCAM X8 WCS PROBLEM
    Your active WCS is indicated in the 1st column, & it is on your bottom plane
    --- your construction & toolplane is still linked to the TOP plane
    the trick is to highlight the plane (name) you want to be active, then hit the = icon (RH side) to make all ( the WCS,C & T) move to that selection
    The tick indicates that that plane is associated within that session ie used in a toolpath operation, stock definition, etc
    - the plane cannot be deleted unless all associations linked to it are removed
    201
    I know about using the = to set all the planes to that wcs but if I move the model around with my spaceball the wcs changes. I do not know where the ISO wcs and the TOP wcs are linked. In the X6 I did not have problem. This is a new problem that I have not had happen to me yet with mastercam.
    Dec 2008
    3109
    Quote Originally Posted by JIMMY View Post
    ah ha
    - that is a setting in the config file
    I think the "Screen" tab ( same page that has "reverse the mouse scroll" )
    the bottom 2 checks to be OFF
    --- ISO view = TOP
    --- and the other that refers to Gview
    Feb 2014
    67
    settings --> config --> cad settings --> "update Cplane and Tplane when changing Gview"
    Attachment 266034
    or lock the WCS
    Attachment 266036
  1. problem with a 3d cut mastercam x6
    By juniormachinist in forum Mastercam
    Last Post: 02-20-2014, 11:09 AM
  2. Pocket problem in Mastercam X5
    By cloverfield333 in forum Mastercam
    Last Post: 12-28-2012, 12:20 PM
  3. mastercam PP problem
    By basim in forum Post Processors for MC
    Last Post: 12-13-2009, 03:27 PM
  4. Mastercam X2 lather problem
    By YamahaR6 in forum Mastercam
    Last Post: 01-17-2008, 04:00 AM
  5. Mastercam problem
    By deckhand in forum Mastercam
    Last Post: 11-22-2006, 06:08 PM
