585,733 active members*
4,889 visitors online*
    Jan 2015
    NT GAS CYLINDER ISSUE
    Hi, new guy on the forum here.
    i was wondering if any of the Mori Seiki NT-4250 machine owner/users had issues with the Sandvik gas cylinder clamping units failing.
    what was the turnaround for parts and what kind of cost was the replacement unit.
    i have heard this is not an uncommon occurrence on this machine tool.
    appreciate any feedback from you all
    Mitch
    Jun 2011
    Re: NT GAS CYLINDER ISSUE
    As far as turn around don't know as we throw them in scrap hopper.
    Price is around $2800.00 for the drawbar.
    We have 12 NT4250 and replace 4-5 a year.
    If you change one DO NOT FORGET to install C - Clip before clamping tool in spindle.
    Jan 2015
    thanks for the reply Vinman, it seems i may have been over charged, the Mori unit i received from Dallas via Toronto came in at $13.8k, i thought too the Sandvik part was cheaper..... anyone know the difference in quality to be $11.4K more expensive.
    what is the issue with the cylinder where you need to change that often, anything you can point a stick at?
    i understand one failing is running without a tool in the spindle, but that is mainly the collet fingers go out of balance.
    why does this cylinder fail ?
    Mitch.
    The replacement cost for Mori Seiki NT-4250 machine part will be around INR11000.
  1. Not Sure What this air cylinder does?
    By CATCH22 in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2012, 12:19 AM
  2. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  3. cylinder
    By copperhead4321 in forum Solidworks
    Last Post: 05-13-2008, 04:20 PM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
