585,556 active members*
3,632 visitors online*
    Oct 2006
    Fanuc 0T Serial port problem
    I have a Fanuc 0T CNC with a defective first serial port (connector M5). Is there a way to enable from software the second serial port (conn. M74)?
    24220
    Set input channel to 2.
    parameters 0050 & 0250 apply (0250 for baud rate)
    Al.
    Albert E.
    Oct 2006
    I've already tried the settings you recommended but it's still not working. I've seen on another thread about Fanuc 0M the fourth bit of 914 must be set. Is this valid for OT as well?
    24220
    I show it valid for 0M.
    Al.
    Albert E.
