What is the M code for bringing the tool probe arm down? I don't have a button. I know it's not a pulldown either.
phoodieman
phoodieman
There should be button for that ???
If it is M code programmed you should found it from "Electric manual".
There isn't, but the arm has been brought up and down with an M code. I just can't remember what it is.
I can get it until monday, but there should be a switch for manually swinging arm down.
Any one that uses automatic tool compensations funktions on a produktion lathe? Looks quite cool when the quicksetter arm swings down and the tools moves with rapid and slows down just before messurement..
M80 /m81
Thank you. Worked right away.
Phoodieman
Are u using the automatic tool compensation funktion? ( G37/G36)
