586,011 active members*
4,151 visitors online*
    Jan 2015
    4
    Question Edit button script
    Any help appreciated. I'm trying to configure a touch probe. It's wired and configured . My understanding is to go to the operator menu and select Edit Button Script. Click on the flashing auto zero and then load the code into the script window. I understand this. The problem is I do not have an Edit Button Script . The only thing close is is VB script. But no flashing buttons to select. I'm not sure what version I have as a friend loaded it for me. If needed I will find out and post. If not any thoughts. Thanks Keith
    Re: Edit button script
    Sounds like you have a really old version of Mach3, maybe 2. something?
    With that version, you needed to use the Screen3 screen designer to add scripts to buttons.
    Jan 2015
    4
    Thanks Gerry
    Is that something straight forward to do? I haven't been to the shop to check the version yet. Or is there another way to add a script to a button. Thanks Keith
    It shouldn't be that difficult, but I've never used that older screen designer.
    Your other option is to switch to a newer version of Mach3.
    Jun 2007
    3757
    With the old screen designer, I found editing was no problem, but ADDING stuff soon hit the wall somewhere (more memory needed?) and the whole screenset would not work properly any more.
    ALWAYS backup the .set file (or .lset for lathe) before attempting to modify it. Along the way you will often hit the mysterious limit(s).
    Never had problems modifying exist button sizes, or anything else, but just one too many additional buttons added, corrupts in many unexpected ways.
  1. Replies: 0
    Last Post: 10-10-2013, 03:41 AM
  2. HOW DO I EDIT VB SCRIPT TO RAISE Z UP 2IN WHEN I PUSH REF ALL
    By ozon in forum Mach Software (ArtSoft software)
    Last Post: 10-10-2012, 10:47 AM
  3. Easiest way to make button run VB script
    By adamchapman in forum Mach Software (ArtSoft software)
    Last Post: 08-16-2010, 08:38 PM
  4. Newbe: edit tool change script
    By jrslick22 in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-08-2010, 09:16 PM
