Hi, I have a lathe fanuc 15t, a friend of mine has canceled the parameters of the machine and now the x-axis to make blind holes the machine does not go to zero but the only iron that I use to make a heading at the bottom of the blind hole is 10 in diameter, however if I put an iron with a diameter larger than the car goes at the end of the stroke and stops at 20 15 30 mm from 0 (depends on which I place) and I from this alarm ' ot X-002 overtravel (soft 1), if I put a tip in the center piece and I go in reverse until the alarm is moving 15 below zero.Please tell me please how to get to the page where I can edit the limit and that limit value to the max I can put? tanks
