585,914 active members*
3,824 visitors online*
    Jan 2015
    4
    Unhappy allarm overtravel
    Hi, I have a lathe fanuc 15t, a friend of mine has canceled the parameters of the machine and now the x-axis to make blind holes the machine does not go to zero but the only iron that I use to make a heading at the bottom of the blind hole is 10 in diameter, however if I put an iron with a diameter larger than the car goes at the end of the stroke and stops at 20 15 30 mm from 0 (depends on which I place) and I from this alarm ' ot X-002 overtravel (soft 1), if I put a tip in the center piece and I go in reverse until the alarm is moving 15 below zero.Please tell me please how to get to the page where I can edit the limit and that limit value to the max I can put? tanks
    Aug 2011
    2517
    Jan 2015
    4
    Re: allarm overtravel
    Sorry for my English but I'm Italian and English is my weak point now is translating google .... my problem is that I do not know the page where to put the new parameters and then go to the tool below without the alarm. Thank You
  1. fanuc 369 allarm
    By jay d in forum Machines running Mach Software
    Last Post: 01-20-2014, 02:13 AM
  2. G99 Overtravel
    By deere2210 in forum OneCNC
    Last Post: 12-24-2012, 06:41 PM
  3. Mazak SQT15MS allarm 37
    By cnc project.net in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-13-2010, 06:54 AM
  4. Servo allarm: 02 (VRDY OFF)
    By bart070481 in forum Fanuc
    Last Post: 10-22-2008, 09:09 PM
  5. 10T Overtravel
    By grease in forum Fanuc
    Last Post: 10-17-2007, 04:19 PM
