40W co2 laser engraving cutting machine engraver cutter cnc
CO2 Laser Engraver Cutter
Laser Type CO2 Gas
Laser Power 40W
Tube Trigger Volt 20KV
Tube Operating Volt 15KV
Current 0-22mA
Interface to Computer USB Port
Maximum Item Size to Engrave 320mm * 220mm * 70mm (12.6W * 8.7L * 2.8H in )
Laser Tube (life hours) 1100-1400 Hours
Engraving Speed 0-350mm/s (0-13.8 in./s )
Cutting Speed 0-35mm/s (0-1.38 in./s)
Minimum Shaping Character 1mm * 1mm (0.04 X0.04in )
Resolution Ratio 0.026mm (0.001 in ) / (1000dpi)
Resetting Positioning ≤0.01mm (0.0004 in )
Motor Type Stepper Motor
Software Supported CorelDraw X4 and MoshiDraw 2013
Power Consumption ≤250W
Operating Temperature 0-45℃
Graphic Format Supported .PLT / .DXF / .BMP / .JPG / .GIF / .PGN / .TIF etc..
Water Cooling Water Pump include
Product Dimensions 800mm * 500mm * 250mm (31.4in * 19.6in * 9.8in.)
Recommended Spare Parts / Consumables Laser Tube, Focal lens, Reflection lens
