585,991 active members*
6,624 visitors online*
Results 1 to 7 of 7
    Nov 2003
    287
    VF-1 Height (head down)
    Does anyone now the min. height with the head down. Wondering if it will go through a 7' tall door. Thanks
    Feb 2011
    212
    Re: VF-1 Height (head down)
    I would like to know this as well
    Nov 2007
    1702
    Quote Originally Posted by vertcnc View Post
    Umbrella or side mount tool changer?
    Umbrella tool changer equipped, VF-1 / VF-2 will fit through a 7 foot door after taking the Z-axis motor off and laying the cable track on its side. Make sure the spindle is secured to a shipping bracket or resting on a block of wood before you take the motor off.
    Greg
    Nov 2003
    287
    Thanks, I was talking umbrella changer. You sound like it's pretty simple to remove the Z axis motor? Probably would have to do it while riggers are waiting, is it doable?
    Nov 2007
    1702
    I didn't personally do it. The Haas tech was here for the delivery. If the z-axis is parked properly against a block of wood or the spindle shipping bracket, the screw shouldn't move when the motor is removed. I think it was four screws and a couple of connectors and it popped right off. I'm not even sure he undid the connectors. He may have just removed the mounting screws and flopped it over on its side on top of the cabinet. Ditto for the wire track. Same for putting it back on. The wire track has some socket head cap screws holding it on. It didn't look like a big deal and I wouldn't hesitate to do it myself the next time it gets moved.
    Will the machine be powered up and parked against a shipping block before it's delivered to you? It should be. The Z-axis shouldn't be bouncing against its bearings during shipment. Are you new to Haas or do you understand how it powers up the first time?
    Greg
    Nov 2003
    287
    Thanks for the info.
    Jan 2007
    161
    Just checked my machine and it is 91 inches with the head all the way down. This is with the older DC servo motor. My roll up door is 8 foot and it slid in with no problems.
    Attachment 266614
    _____________
    teamjnz
  1. Series 1 Boss 3 Head Rebuild (2J Head) - Stuck Here.
    By 1875 in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2022, 07:59 PM
  2. NEWBIE NEED HELP HOW TO CONFIG 5 AXIS HEAD HEAD B/C MACH 3
    By plast744 in forum Mach Software (ArtSoft software)
    Last Post: 07-14-2014, 02:57 PM
  3. Replies: 1
    Last Post: 04-30-2009, 02:11 AM
  4. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
  5. Mini Mill Head Height
    By dropride in forum Benchtop Machines
    Last Post: 12-04-2005, 12:39 AM
