Does anyone have any tips on machining epoxy tooling board? Feeds and speeds, step-over and cusp height, tooling and such.... I'm trying to get a fine surface finish to make a composite mould from.
Mick
Mick
is there fiber glass in it? if not, just about anything should cut it.
Do you have a brand name for this material?
No fiberglass in it i don't think... From a company called base, type is 978 high temp (the blue stuff)
Climb mill it, Watch the corners for breakout. Spiral in towards the center. I'm not familiar with the brand you are using, but I've cut a lot of Ren 450 and Redboard for foundry patterns. The redboard is extremely hard and chippy. Ren 450 is very forgiving, similar to the old Butterboard material.
If at first you don't succede destroy all evidence that you tried!
