585,754 active members*
3,855 visitors online*
    Aug 2014
    889
    Gcode convert
    Hi, can the edingcnc controller accept standard Fanuc gcode, or does it need converting?
    Also, how difficult is it to modify or change the GUI?
    Can Pokeys 57 work with this controller without too much problems?
    Aug 2014
    889
    Re: Gcode convert
    After reading the manual, it can do everything I need. The sdk will allow customization of the GUI, which is a big plus. Too bad Canadian dollar is so low.
  1. I will pay for someone to convert STL to Gcode (mach3)
    By Davidodem in forum Want To Buy...Need help!
    Last Post: 07-20-2013, 07:32 AM
  2. How to Convert 3D Drawing DFX to GCode?
    By pa2012 in forum G-Code Programing
    Last Post: 06-07-2012, 04:52 PM
  3. Convert 3D animation to Gcode
    By druitre in forum Uncategorised CAD Discussion
    Last Post: 09-15-2011, 09:29 AM
  4. Convert Gcode units
    By NickAshton in forum G-Code Programing
    Last Post: 01-25-2009, 10:48 PM
  5. convert se to gcode
    By ata in forum G-Code Programing
    Last Post: 04-27-2007, 08:06 AM
