585,712 active members*
3,883 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Need help Trouble shooting X axis will only move one direction
    Jan 2015
    All,
    I am new to CNC and need some help getting my machine working again. I have been using it for two months with no problems using for woodworking projects. I have about 100 hours of use on the cnc
    I am running Mach 3 and all my G code is generated thru artcam.
    I have a made in china 6040 with 4th axis which I have not used yet.
    I was cutting out some inlay pieces which the program takes about 1 1/2 to complete. I left my machine running for 20 minutes and came back and my X axis went postal.
    It jogged all the way to the left my negative and would not move back to the right. My arrow keys all work except for the right arrow key when pressed it moves to the left. The Mach 3 program showed the arrow keys working correctly
    I thought I might have a bad motor and swapped x and y cables and still had same problem the right arrow key went opposite direction on other motor.
    I opened the cnc control panel and run some air thinking my wood dust did something NO LUCK.
    ANY HELP OR SUGGESTIONS WOULD BE GREATLY APPRECIATED
    Jeff
    Jan 2015
    Re: Need help Trouble shooting X axis will only move one direction
    My issue is the stepping driver, I am ordering a new one.
    I want to thank Jeff for helping on this issue, what goes around comes around.
    Thanks again Jeff for your help
    JAJ
  1. How to setup JOG control to move 2 axis with each direction key
    By MickPaul in forum Mach Wizards, Macros, & Addons
    Last Post: 06-29-2013, 12:06 PM
  2. Trouble shooting
    By PlasmaCraft in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-16-2011, 08:18 AM
  3. x axis will only move 1 direction
    By brent48 in forum Stepper Motors / Drives
    Last Post: 11-09-2010, 06:25 PM
  4. x axis will only move one direction
    By CATCH22 in forum Mach Mill
    Last Post: 12-17-2007, 03:53 AM
  5. Trouble Shooting Help
    By Outlaw6700 in forum Milltronics
    Last Post: 08-21-2007, 03:22 AM
