584,865 active members*
4,913 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > Ethernet Smooth stepper, C32 board MPG4 Pendant, New having trouble setting up.
Results 1 to 7 of 7
    Feb 2014
    227
    Can someone explain how to connect the MPG4 Pendant to a C32 board from CNC4PC? I have everything installed but for some reason I can't get the Pendant to work. The directions talk about Brains and Plugins, well if you don't know what Brains are how can one install them or know what configuration to read. The Pendant plugs right into the C32 board and then from what I can tell you have to set up the Port and Pins in Mach3. I am at a loss and not sure how to set this thing up. Thanks for the Help in advance.
    Jeff
    Re: Ethernet Smooth stepper, C32 board MPG4 Pendant, New having trouble setting up.
    Quote Originally Posted by ballistic42 View Post
    Jeff
    I too am trying to connect the https://cnc4pc.com/motion-control/mp...s-pendant.html to my c62 board. Did you every figure it out?
    Feb 2014
    227
    Quote Originally Posted by cwciwatch View Post
    Yes I figured it out a long time ago. I can tell you how to do it and give you all the ports, pins aND how to get the brain if you would like. I am out of town and get back on Tuesday. I can have it working for you real quick.
    Mar 2017
    4
    im having the same issue did you ever get it figured out??
    Mar 2017
    4
    Thanks for the help but I finally figured it out. Still can't get the step selection tho?
    Apr 2013
    Hello,
    If you are back in town can you please tell us how to get this pendant going?
    Nov 2007
    361
    Quote Originally Posted by blair4 View Post
    Hello,
    So did you get this fixed ? It would be great to know what you did to get this fixed so we can share with others that are having the same issue
  1. G540 with an Ethernet Smooth Stepper
    By dmauch in forum Gecko Drives
    Last Post: 04-04-2015, 06:21 PM
  2. Replies: 0
    Last Post: 01-30-2015, 10:42 PM
  3. ethernet smooth stepper
    By daniellyall in forum Mach Software (ArtSoft software)
    Last Post: 08-08-2013, 07:40 PM
  4. Smooth Stepper Ethernet Board - Mach3
    By mrpackethead in forum X3/SX3/G0619/G0463
    Last Post: 05-09-2013, 02:04 PM
  5. Replies: 1
    Last Post: 10-05-2012, 12:24 PM
