585,767 active members*
4,076 visitors online*
Thread: EMC on XBox
    May 2006
    2420
    EMC on XBox
    Would it be possible to run EMC on an Xbox with linux installed?
    I guess the lack of parallel port would be a major sticking point.
    Any thoughts ?
    Russell.
    Oct 2006
    4
    hi, just try the livecd or the puppy one...
    does emc do usb-controller?
    Jan 2006
    63
    Yeah. EMC would run under linux on an xbox with linux installed. The xbox is pretty much just a standard x86 machine.
    The problem would come with interfacing EMC to a driver... You only get USB =)
    Edit:
    Also, Normal linux distributions won't install easily onto the xbox because of the fact that the xbox does not have a normal BIOS... Special kernel options are needed in order to boot the OS as well. You will need to look for an xbox ready distro.
    May 2006
    2420
    Thanks guys, kinda what I thought, still might be worth a look, plenty of cheap xbox's around now since the new one came out...
    Russell.
