585,987 active members*
4,504 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D / Cut3D > Editing Postprocessor
    Mar 2004
    636
    I am wanting to add a line of code to all of my files generated by Cut2D. This is just a simple line to home the x and y axis only. I do not want it to change z at all. I believe I can do this by editing the post processor file. When opening the postprocessor, I find a few lines at the end of it that are as follows:
    + Commands output at the end of the file
    begin FOOTER
    "[N]G00[ZH]"
    "[N]G00[XH][YH]"
    "[N]M09"
    "[N]M30"
    Currently I set my home position in cut 2D at X2, Y2, Z2 and it provides rapid travel to these postions. I still want to do that, but have it home x and y right after that. I am also wanting to add a spindle shutoff just before that. This is what I feel the codes should look like to make that happen.
    begin FOOTER
    "[N]G00[ZH]" - Rapids Z to 2"
    "[N]M05" - Turns off spindle
    "[N]G00[XH][YH]" - Rapids X and Y to 2"
    "[N]G28.1 X0 Y0" - Tells machine to home X and Y
    "[N]M09" - Mist and Flood off (not needed in my case)
    "[N]M30" - Program end and rewind
    I believe this is correct, but I wanted a second set of eyes to look if you could.
    Dan
    Check out what I am working on at www.routerbitz.com!
    Re: Editing Postprocessor
    Looks OK. But I'd turn off the coolant right after the M5, rather than after homing.
    Mar 2004
    636
    Thanks Gerry, Although I do not use coolant, the logic makes sense. Why would I want it spraying all the way through the homing sequence. I will move it just after the M05.
    Dan
  1. Help editing post
    By dkrenfrow in forum Mastercam
    Last Post: 04-12-2012, 09:10 PM
  2. Editing a toolpath
    By jwelin in forum MadCAM
    Last Post: 05-06-2010, 11:18 AM
  3. Need help editing post
    By bugzpulverizer in forum Post Processors for MC
    Last Post: 08-25-2008, 05:35 PM
  4. Editing post
    By WingNutz in forum Mastercam
    Last Post: 08-15-2008, 03:43 AM
