585,992 active members*
5,588 visitors online*
Results 1 to 13 of 13
    Oct 2012
    24
    Unhappy Mazak 6200Y 26 illegal parameter
    hi good day
    we have a machine here a Mazak 6200Y/mazatrol 640T.. it loads a UI but there a asterisk display after that the alarm appears and maybe someone has an idea this kind of alarm "26 illegal parameter". im planning to reset servo/spindle parameter but we didnt know how to do it..we just only want to try maybe could
    work on that way.. thanks
    Oct 2003
    321
    Re: Mazak 6200Y 26 illegal parameter
    Quote Originally Posted by leiryll View Post
    hi good day
    can you give some pictures of the monitor, may be also alarm history.
    best regards
    mazak-user
    Oct 2012
    24
    im sorry idont have screenshots.. but have these...
    Description Type
    26 illegal parameter servo/spindle
    17 2 port memory parity MCP
    351 spindle contactor fault machine
    381 COND. Missing(Set up SW) machine
    121 overtravel NC
    491 maint. check warning operate
    well.. i changed the battery already from NC panel which is already dead.. the next thing is to load parameter of a machine that i dont know yet.. and we have a diskette and memory card that we also found from back portion of a NC/MCP panel.
    Oct 2003
    321
    Description Type
    121 overtravel NC
    what type of control you have?
    T-Plus or Fusion 640TM
    best regards
    mazak user
    Oct 2012
    24
    Quote Originally Posted by mazak-user View Post
    best regards
    mazak user
    fusion 640T..
    Oct 2003
    321
    If you switch on the main breaker, and then push the on button on the control, start on windows or not?
    Oct 2012
    24
    yes it is.. the Windows OS load and its UI..and you cant shutdown by pressing a button.. just machine main breaker.. and the problem is, there's an error appear on screen. the spindle and servo module has its on flickering error too but i figure out that the modules has no concern on it. because i saw some garbage text and number displayed on MCP,it display some are asterisk.. some what i thought maybe the machine NC parameter been corrupt... so i planned to overwrite the parameter and reboot again..
    Oct 2003
    321
    give me your mailadress.
    Oct 2012
    24
    [email protected]
    Oct 2012
    24
    thanks for the guide it helps me alot
    Oct 2003
    321
    Its Ok.
    Best regards
    Mazak-user
    Mar 2013
    Is some body still there
    Now I have the same problem in my Mazak 620 T Plus control
    Any idea how fix it?
    Thanks a lot
    Jan 2023
    Quote Originally Posted by torresr View Post
    Thanks a lot
    I'm now in the same boat. I have this error on my 1998 QT250HP Fusion 640T. Is this a reload the backed up parameters type of thing or is it something different? Any help would be greatly appreciated. Thanks in advance!
    Error reads as follows
    26 ILLEGAL PARAMETER( 1, 36,&0037)
  1. Mazak VQC 20/40B Zero Return Parameter
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-19-2017, 10:41 PM
  2. multiplex 6200y
    By programmer01 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-28-2013, 08:52 PM
  3. Mazak 6200Y Multiplex
    By soxfan1487 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-24-2012, 07:03 AM
  4. Mazak M plus parameter?
    By MrUZU1 in forum MetalWork Discussion
    Last Post: 06-09-2007, 02:50 AM
  5. Mazak OP2 parameter
    By xr135 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 08:11 PM
