584,850 active members*
4,416 visitors online*
    Feb 2015
    12
    Mach3 Feeds are slower than specified
    Hi All
    I have just set up a machine and I have done some test cuts, if I do a test with a square pocket the machines cuts fine but anything at all with any kind of radius or circle in it the feeds just drop down to an absolute crawl and I can work out why.
    the maximum velocity in my machine is set to 750 and if specify a square pocket with a feed rate of 750 the machine will cut it fine and mach3 behaves as it should, if do say a circle and specify any feed rate at all it disreagards it and cuts at a feed rate of about 5% so a 6mm hole in a piece of mdf takes about 10 minutes to cut
    I really hope someone can point me in the right direction as I am pulling my hair out here
    Cheers
    Dec 2010
    19
    Re: Mach3 Feeds are slower than specified
    someone with more experience may have a better answer, but my first thought was what is your acceleration set to? Also, what is your CAD and CAM package? Some CAD/CAM programs (if I remember correctly) actually turn circles into short arc segments. which could possibly explain the slow feed rate - your machine may not have time to fully reach the feed rate. Have you tried to manually write g-code for a circle and try that?
    Feb 2015
    12
    Quote Originally Posted by idahoflyfisher View Post
    Hi
    My acceleration is set at 60
    I am using bobcad, I tried using the circle wizard in mach3 and it does the same thing, still slow
    Feb 2007
    505
    when doing your tool selection there is a setting call arc slowdown
    Post some simple g-code that does what you're describing.
  1. RPM is running much slower then inputed rpm
    By TheGreenMachine in forum Fadal
    Last Post: 05-25-2021, 11:17 PM
  2. Why is one Tormach SOOO much slower than the other one?
    By toothandnail in forum Tormach Personal CNC Mill
    Last Post: 02-25-2013, 02:42 AM
  3. X axis runs 50% slower than Y
    By Inuk in forum Excitech routers
    Last Post: 12-27-2010, 03:05 AM
  4. Mach3 Feeds & Speeds
    By IMK1230 in forum Mach Wizards, Macros, & Addons
    Last Post: 06-30-2009, 10:24 AM
  5. Slower Jog Speed
    By rweatherly in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-18-2006, 07:33 PM
