I use Bobcad's generic 3 axis mill post for running on my Fadal. It works fine for everything except tapping so I would always just edit the code by hand if I needed to tap. This morning I decided to take the time to fiddle with the post so it would output what I need. I figured out how to do everything except remove the M03 and M08 commands from the beginning of the program. I only want it to leave those out when tapping and use them on all other operations. Can this be done or do I need two separate posts? My modified version is attached.
