584,812 active members*
5,484 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > Syil 5 linear conversion.
    Apr 2004
    52
    I have just received the DMM 4 drives and 400 watt motors I am going to use on the Syil 5 I purchased several years ago while in Mongolia. I am back in the US and want to convert it to AC servos. It is a small mill witha 12 X 6 X 11 " travel. It has Hiwin slides and ball screws on all axis. I have looked for some time at different options and played with Granite drives for a time but settled on new servos and drives.
    Shipping was prompt and I have been able to play with one of the drives and motors. The motors are suprisingly small but run very quite. For testing I am using 120v but will use 220v in the machine. The drives are capable of running larger motors but I think the 400w is enough.
    I'm still deciding on the spindlr drive. The original is the Samtung 1100 watt BLDC. The new 5's have aVFD. I did get a new Marathon Max Inverter 3phase motor that should arrive next week but I think it might be to large. Any way I will post as I get time.
    Larry
    15362
    Re: Syil 5 linear conversion.
    2ndSteel
    The Dmm is a good choice for your drive system, you may need a 750W motor for the Z axes, depending on how balanced it is
    Mactec54
    Apr 2004
    52
    That is one reason I went with the Dyn4 drive is so I can move up to a bigger z motor. I wanted to see what it does. It is balanced with a spring shock and is on linear guides.
  1. Syil x5 linear guide type?Please help.
    By shedbob in forum Syil Products
    Last Post: 08-11-2011, 01:35 PM
  2. Syil X3 Conversion kit
    By f757lkk in forum Syil Products
    Last Post: 09-29-2009, 04:20 AM
  3. Linear Encoder With Syil x4
    By obrif in forum Syil Products
    Last Post: 09-09-2009, 11:30 PM
  4. Syil X2 CNC Conversion Nightmare
    By IMK1230 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2008, 10:46 PM
  5. Travel limitation on Syil X3 conversion
    By Greolt in forum Benchtop Machines
    Last Post: 08-13-2006, 12:26 PM
