1.When I load a g-code file, Mach3 will arbitrarily not generate a toolpath. I have to reload Mach3 several times, and eventually it will generate a toolpath.
2.I was under the impression that you can jog over to a spot on the table and zero the work coordinates. If thats the case then my zero buttons are not working. ?? I use "Big Tex blue screen" and the laser zero button works.
3.If I hit the "goto z" button (in work coordinate), the X-Y axis start moving and will drag the z thus causing a crash.
I am a newb, and I've printed out the Mach3 manual and have tried to read it cover to cover (yawn,yawn), and I can't find the answer.
So, just tell what information would be helpful to solve these problems and I will gladly provide them.
Any help is greatly appreciated.
OSD
Mach3 Version R3.043.066
Window XP
Gantry rounter
Y A slaved
