585,933 active members*
3,878 visitors online*
Results 1 to 10 of 10
    Jan 2007
    161
    More memory needed
    I have run into a problem a couple times now where my programs are to larger for the memory. My 1994 Haas has 3/4 meg of memory available. No floppy drive only RS232 and I can't figure out how to get the machine to receive code via DNC. Do Haas machines have a parameter setting increase memory or is it a memory chip on a board?
    _____________
    teamjnz
    Mar 2010
    1852
    Re: More memory needed
    Setting 55, Enable DNC From MDI. Also, if you are sending line numbers and all of the comments etc., delete them to save memory. Memory size is fixed unless you have it physically added, don't believe it is already there and needs to be turned on.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    I've always ran from 'tape' mode when program too large....this will drip-feed the program to control.
    Joe Elson - Engineering
    email: [email protected]
    Like Silver said you could drip feed from the computer, or as another option check out info on portable drip feeds which you plug into an RS232. Here is one that we have but I will admit it has been a bit buggy: Data Shuttles - Memex Automation
    Multi-Tasking Machining - Customer savings, and shorter lead times!
    www.northernmachininginc.com
    Jan 2007
    161
    Thanks Guys. I just got a quote for the Memex Data Shuttle and it is $760.0 with shipping.
    My machine does not have the floppy drive so I wounder if one can can be installed if the machine already has the options in it. If so I think that placing a USB floppy emulator in it place would be a thing to try. The USB floppy emulator already exists for around a $100 bucks.
    _____________
    teamjnz
    I agree that sounds like it would be the way to go, and an idea that may be worth us looking in to. How would that work at the machine though. Is there a way to make the machine look at a different drive, instead of it's normal location for running a program?
    Jun 2013
    1041
    The usb floppy drive may not work for you. It is tricking the pc into believing its a floppy drive. The max file size will still be 1.44mb just like a real floppy.
    Ben
    just use a laptop in front of the machine and hook it up via rs232 ports....you'll see the nc code on the laptop.
    Silver,
    Don't know why I was never able to think about doing that ourselves. That is even better yet. Thanks!
    Chad
    anytime
  1. Replies: 0
    Last Post: 01-27-2015, 02:31 PM
  2. OT-A Memory help needed
    By JPROCT in forum Fanuc
    Last Post: 07-23-2014, 06:17 PM
  3. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  4. Arrow CT C80010 Memory module needed
    By Larry Callahan in forum Cincinnati CNC
    Last Post: 12-08-2009, 10:27 PM
  5. Mitsubishi memory card FX727B needed
    By ronmor in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-10-2008, 05:54 PM
