585,715 active members*
3,718 visitors online*
Results 1 to 6 of 6
    Aug 2007
    39
    Torch height control
    I am in the early stages of planning a cn plasma.
    One important question: Do I absolutely need a THC, or can I get away without it?
    Nov 2007
    343
    Re: Torch height control
    Can you get by without one - yes. Can you do consistent good cuts without one - no. Get a THC and avoid problems and non satisfactory results.
    Sep 2011
    102
    I wouldn't even want to try and cut without torch height control. It is very common for steel to warp when it is being cut. I've seen steel warp as much as 1/2". The torch height control will compensate and prevent issues.
    Jun 2009
    226
    It's virtually impossible to get quality cuts on thin material (< 10GA) without THC. If you are planning on using Mach3 for your control software, then look at CandCnc. Tom makes a variety of systems from the LCTHC, a low cost, barebones but very good THC, to systems that do everything but the drawing. Just depends on how much you want to spend.
    Willy
    Mar 2004
    413
    I'm in the "depends upon" camp.... What is your cutting intentions ? What exactly do you want to make ? Thin, uneven sheet metal will demand a THC whereas if you cut materials that are .060">> or say .090" and thicker, that can be cut very successfully without THC. I do it all the time.
    The next level of depends is how accurate you can build your machine to be ? How PARALLEL can you get your material to lay with the torch plane ? I've seen large format machines demand THC on ALL thickness of materials simply because the machine was set up completely crooked having the table plane completely wacked compared to the torch motion plane.
    Obviously, a smaller work area is easier to make true. I have a 30" square work area portable machine that is very true, and because I generally do not cut thin sheet, works just fine without THC. I apply all the other typical requirements though, such as finding the surface and setting the proper pierce and cut height on the fly.
    Your best option may be to build your plasma dream incrementally. Build yourself a very accurate, parallel and true machine with a properly powered Z axis (and zero height detection) so it is there and as such, eventually useable by a THC when and IF you desire it. No harm in that. You may get along just fine until you feel you need it.
    So the truth in the matter is NO, THC is not just an "automatic requirement" for CNC plasma you have to throw money at just because its there..... Like anything else, it DEPENDS on what YOU are trying to do with the machine.
    Chris L
    Apr 2006
    54
    Quote Originally Posted by drieslaas View Post
    Yes, absolutely you need, because we produce THC :-) visit our we page Capacitive Sensor
    If you dont want to use THC you must protect your torch with magnetic breakaway, AGELKOM News Page
    Best regards,
    Argun Gucdemir
    Agelkom Ltd
  1. Torch Height Control
    By ita333 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-27-2014, 07:39 AM
  2. Torch height control
    By Bobnire in forum Waterjet General Topics
    Last Post: 12-16-2012, 10:48 AM
  3. Need better torch height control?
    By Karl_T in forum Waterjet General Topics
    Last Post: 04-27-2009, 05:36 PM
  4. Torch Height Control
    By luther in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-12-2007, 09:51 PM
  5. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
