I've been going over a milling machine I acquired recently, fixing various things, and the x-axis ball screw is a little out of place. The machine is from around 1991, and the most similar model I can find on the internet is the YCM40 Supermax.
Here's a picture of the outboard end of the ballscrew.
Attachment 267656
The end of the ballscrew doesn't stick out quite far enough to get a circlip on there. I know that it should have one because, when I removed the cover, there was one in there, and it had gotten bent as the screw moved and the circlip was forced off.
Here's a picture of the motor-end of the ballscrew.
Attachment 267658
The ballscrew needs to move through this housing by maybe 1/16 so that I can get the circlip back on. I tried loosening the collar in the center -- I mean the one between the pulley and the black ring -- by loosening two set screws and tapping on the keyway-looking groove, but no dice. I can see that someone really whaled on this at some point. One of the keyway looking things has a deep groove like someone pounded tangentially with a hammer. I tried pounding in the opposite direction, but it wouldn't go, but I didn't want to pound on it very hard.
I would have a better idea what to do if I had some idea how this all went together. Anyone been down this road?
Randall
