585,602 active members*
3,513 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Minimizing wasted cutting time.
Results 1 to 6 of 6
    Jan 2014
    5
    Hello, I am hoping someone here can help with with a problem I am having.
    I am trying to cut a round wire groove into a piece that has already been cut to the desired shape in the EDM. I am using Surface Rough Parallel to rough the slot into the material and using Surface Finish Parallel to finish. I am having issues with the roughing cut cutting air over the radius as (hopefully) shown in the picture. Is there a way to minimize this? Maybe am I using the incorrect toolpath for what I need to do?
    Please let me know if I need to clarify anything to help you help me. Thanks for your time!
    Dec 2010
    1230
    Re: Minimizing wasted cutting time.
    "rough" removes material from assumed/understood stock.
    "finish" will follow the final surface.
    Use surface finish for both and manually tell it "stock to leave" to create your "roughing" passes. Multiple passes can be done with multiple identical operations by decreasing "stock to leave" on each op
    Brian
    WOT Designs
    Jan 2014
    5
    Thanks, I will give that a shot. Is there a way to tell the "rough" toolpath what the assumed/understood stock is? I went into the stock set up page and was able to make a stock solid model of my part before the groove was milled in but I couldn't figure out if I could tie any parameters to said stock model.
    Again, thanks for your help!
    Dec 2010
    1230
    That's a question for another fella unfortunately. I don't do very much 3d. In fact I have switched over to hsmxpress for 90% of what I do. Still used master cam for occasional 3D and engraving only
    Brian
    WOT Designs
    Jan 2014
    5
    Well thanks again, the whole stepping the finish down with leaving stock on the drive worked great!
    Dec 2013
    6
    Using High speed core rough tool paths you stay in contact more often then using any of the surface rough tool paths
  1. TOOL CHANGER WASTED TIME
    By cncbeastmaster in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2013, 04:03 AM
  2. Help Minimizing Chance of Lost Steps
    By mayhugh1 in forum Gecko Drives
    Last Post: 08-14-2009, 04:04 AM
  3. wasted motion on pockets
    By rardoin in forum BobCad-Cam
    Last Post: 06-04-2008, 01:15 PM
  4. Minimizing air consumption on Haas VF-3 2001 model
    By conceptmachinin in forum Haas Mills
    Last Post: 11-20-2007, 05:01 PM
  5. minimizing chatter
    By Runner4404spd in forum MetalWork Discussion
    Last Post: 01-24-2006, 10:13 PM
