Hi all,
One month ago everything worked fine, I sended the prograsm with a FTP by the ethernet without problems. But now the Fanuc 18i-i MB doesn't have conecction with the net, I send pings to the net and doesn't work.
Now I tried to re-configure the ethernet options, I want to change the channel, de router ip and more things to solve the problem.
1.- The first thing it is I cant change the parameters because I can't find the Parameter PWE (protect write enable). I follow the instructions of the manual (in the image) but I can find it.
Attachment 268198
2.- Any advices or suggestion to solve the configuration problem? I don't think that would be a hardware problem, is not so common.
Thank you.
