584,330 active members*
7,030 visitors online*
    Feb 2015
    Question drill, ream, and install dowel pin
    Hello all, I'm new here and come for some help. I am trying to figure out the correct way on how to drill, ream, and install a dowel pin into a forged steel automobile crankshaft. The dowel pin is 3/16" O.D. Dowel Pins | MSCDirect.com
    Does anyone know which would be the proper size drill bit and reamer I would need to do this? Also, what drill bit material would i need to be able to drill into forged steel? Note: I only have to go in a tad less than a half of inch into the forged crank. Thanks in advance
    Feb 2015
    174
    Re: drill, ream, and install dowel pin
    Rockwell? (The steels hardness). #15 drill (.180) then a .1875 reamer? I'm guessing here, the need for carbide would suck. Need a bit more info.
    Feb 2015
    Quote Originally Posted by stucapco View Post
    there is no information out there which states the rockwell of the crankshaft. i did find another thread with someone else doing the same thing, he even links which drill bit and reamer he used. heres the link: pinning the crank
    i see the guy in that thread used 11/64" bit which is smaller than a #15 drill bit. should i get a #15 brill bit instead? i would assume it would be easier on the reamer.
    let me know if thats fine or if there is a better way to do this. thanks
  1. Drill a hole through 1/4" dowel rod
    By Jack Burton in forum WoodWorking Topics
    Last Post: 02-18-2012, 01:28 PM
  2. Ream feature
    By dlaery in forum BobCad-Cam
    Last Post: 02-16-2012, 09:46 PM
  3. How to ream hole with no drill baby, drill
    By tome9999 in forum BobCad-Cam
    Last Post: 03-05-2011, 05:09 AM
  4. Replies: 6
    Last Post: 05-01-2009, 10:29 PM
  5. How to sharpen Dowel Drill Bits - Brad Point
    By bignimmer in forum MetalWork Discussion
    Last Post: 11-01-2006, 11:48 PM
